Inputs or parameters with the "\\" are getting changed to "backslash" when testing upgrade to FME Form 2023.1.0.0.
Why are inputs or parameters the "\\" is getting changed to "backslash" when using FME Form 2023.1.0.0? Seeing it happen on Workspace Runner for log file as well as database name on database joiner. How wide spread is this issue? Previous version was 2021.2.0.1
  • October 6, 2023
Can you post some screenshots and/or log extracts, please.
  • October 6, 2023
I have attached an example log file. The log file is a parameter that pulls from a SQL Table. The other scenario is in the DB joiner in FME2021 vs 2023. When I open the workspace in the new version it puts "backslash" in when defining the server name in the first parameter.
