How to wait for (log) file to finish ?
lifalin2016
Forum|alt.badge.img+29
If I create one master workspace, that runs a number of sub-workspaces, these start and create their own log file. Each workspace will run in its own core/thread, which performs faster.
If I (in the WorkspaceRunner) select to wait for each sub-workspace to finish, all sub-workspaces are run sequentially, one after the other, in a single thread. This is not what I want.
If I want the master workspace to wait for all sub-processes to finish (without blocking other processes), e.g.. by waiting for them to release the write access to their log files, how would I go about that ? I want to be able to gather and check the content of all log files for some after-process Q&A.;
I've tried to utilize Python to test for write access ("if not os.access(filename, os.W_OK):"), but it doesn't seem to work.
Has anyone succesfully done something of this sort ?
Cheers
Lars I.
verdoodtdries
Forum|alt.badge.img+19
Hi @lifalin2016,
Can your problem be resolved by connecting the three output ports of the WorkspaceRunner transformer with a FeatureHolder?
  • October 12, 2016
Hi @lifalin2016, it seems to be difficult to directly detect log file completion. However, log file of a workspace will be closed before the shutdown process, so creation of a file while the shutdown process may be used as a signal of log file completion.
If the master workspace generates unique signal file path and passes it to the sub workspace through the WorkspaceRunner (i.e. through user parameter of the sub workspace), a PythonCaller after the WorkpaceRunner can wait for creation of the signal files. e.g.
import os, time
class FeatureProcessor(object):
    def __init__(self):
        self.features = []
    def input(self, feature):
        self.features.append(feature)
    def close(self):
        for feature in self.features:
            path = feature.getAttribute('_signal_file_path')
            while not os.path.exists(path):
                time.sleep(0.2)
            self.pyoutput(feature)
  • October 12, 2016
In addition to the other answers, you could also simply read the log file and look for the following text on position 33 of each line:
INFORM|END - ProcessID:
This would signal the last line of the log file after the workspace has completed. If you don't find it, wait a couple of seconds and try again.
lifalin2016
  • October 13, 2016
verdoodtdries wrote:
Hi @lifalin2016,
Hi @verdoodtdries
Using a FeatureHolder after each launch defeats my purpose, as I want to submit all workspaces more-or-less simultaneously, and only wait for their completion after all have launched.
And if I only add a single FeatureHolder after workspace #4, I don't think that I can be sure that the other workspaces have finished. Or am I missing something here?
Cheers
Lars I.
lifalin2016
  • October 13, 2016
Hi @david_r
How do I wait a couple of seconds in the workspace without hanging or blocking the process ?
Cheers
Lars I
lifalin2016
  • October 13, 2016
Ah, just saw the Python command "time.sleep()" mentioned in @takashi
's post. That might do the trick.
lifalin2016
  • October 13, 2016
import os, time
    def __init__(self):
        self.features = []
    def close(self):
                time.sleep(0.2)
Hi @takashi
Thanks for the example.
Using a file to signal something is a strategy I did think about, but it's very old-school, and not very elegant. I had hoped for some better and more elegant idea, but maybe it's the only way.
I assume that the features in your example are the "succeeded" features from each workspace, that I get immidiatedly after launching the workspaces (because I don't want to wait for them to complete) ? The attribute "_signal_file_path" should then be unique to each workspace, correct ?
Anyway, thanks for the tip on "time.sleep()", that tidbit eluded me when I looked into using Python myself.
Cheers
Lars I.
lifalin2016
  • October 13, 2016
Hi again @david_r,
Do you know whether it's possible to read the log file (multiple times) while the workspace is still running ?
Cheers
Lars I.
verdoodtdries
Hi @lifalin2016,
Hi Lars @lifalin2016,,
In that case, you can combine all the Summary output-ports of the WorkspaceRunner transformer to one FeatureHolder.
I think that can be sufficient to test if all sub-workspaces have finished.
If not, you can add a PythonCaller with a script that executes following while-loop:
- Read all sub-workspace logfiles.
- Check whether the sub-workspace has finished by searching for the specific line in each logfile as @david_r suggested.
- Continue or wait for a moment with the time.sleep() command as @takashi suggested.
Good luck !
  • October 13, 2016
lifalin2016 wrote:
Hi @takashi
Cheers
Lars I.
Exactly. The TempPathnameCreator (FME 2016+) is useful to create unique file paths for each feature.
  • October 13, 2016
lifalin2016 wrote:
Hi again @david_r,
Cheers
Lars I.
Sure, just be sure to close and re-open the file handle for each iteration.
