How to take a string (RegEx) within a current attribute and make a new field with it?
  • April 18, 2022
  • 189 views
juliarozema
Forum|alt.badge.img+10
I have a string in a attribute. At the end of the string there are brackets containing one or more words. I would like the contents, including the brackets to be put into a new attribute.
Ex:
Attribute = "cat mouse (cheese crackers)"
Desired new attribute = "(cheese crackers)"
NOTE: sometimes there is one, two or more words with in the brackets, and I want all of them in the new field.
Using a RegEx (\\(([\\w]+( [\\w]*)*)\\)$) I can select that portion of the string, but I don't know how to put that portion into a new attribute.
Currently I have an AttributeCreator
with Attribute Value = @FindRegEx(@Value(Attribute),"\\(([\\w]+( [\\w]*)*)\\)$")
but the result is not the string, but numbers.
Thank you in advance for your time.
Julia
Best answer by dustin
I would use the StringSearcher with regex \\(.+\\)
You can then specify the output attribute, or leave as _first_match.
dustin
Forum|alt.badge.img+31
  • April 18, 2022
juliarozema
  • April 18, 2022
Woohoo! Thank you!
