How to Snap Points to the Nearest Location on a Polyline in FME 2023?
gbcfgeo2025
Forum|alt.badge.img+3
Hi Community,
I'm working with FME 2023 and I need to snap these purple points to the closest locations along the yellow polyline. What's the best way to do this?
How do I use the Snapper transformer properly in this case?
Could you please share an example workspace?
I've attached the relevant data—thanks in advance for your help!
alexbiz
Forum|alt.badge.img+30
  • June 16, 2025
You might want to use the AnchoredSnapper transformer instead.
  • June 17, 2025
Hi ​@gbcfgeo2025 ,
If the requirement was to snap the points to the closest vertex of a line, AnchoredSnapper (Snapping Type: Vertex Snapping) would work as expected. However, I think a combination of NeighborFinder and VertexCreator would be better, if you need to snap the points to the closest location on a line regardless of it matches a vertex or not.
  1. NeighborFinder : Send the point features to the Base port, send the line features to the Candidate port.
  2. VertexCreator (Mode: Replace with Point) : Move the points to the closest location on a line.
Just be aware, the coordinates of a moved point could not match the coordinates of a point on the line with mathmatical precision, since there must be an unavoidable calculation error with computer calculation.
