How to practise String searcher
Hello,
I want to extract from a .txt file the size of an object, it looks like: Size: 1575200 .
I am using StringSearcher to find it in the text file, the regular expression is like : Size: [\\s\\S]*$
It works well, but I want toget only the value, so 1575200 and not like Size: 1575200
Do you have any idea?
Best answer by ebygomm
If you only want the numeric value after 'Size:' you could also use the following regular expression
(?<=Size: )\d+
Forum|alt.badge.img+50
What you could do after you've found the matches is use a StringReplacer to replace "Size: " with an empty string.
  • August 26, 2019
You can also use the following regex:
And specify the subexpression list name "_subs" under Advanced settings:
You will then find the size value under "_subs{0}.part" which you can rename as you wish.
Forum|alt.badge.img+39
  • August 26, 2019
(?<=Size: )\d+
  • August 27, 2019
(?<=Size: )\d+
Thanks!
And what if there is not numeric value, but text. Like: SIze: Medium and I want to get only Medium?
  • August 27, 2019
gylona wrote:
Thanks!
You could use \\w instead of \\d which will match any word character (letter, number, underscore)
gio
Forum|alt.badge.img+15
  • August 30, 2019
AS he said his regexp is ok.
He just did not "capature" his needs.
So to capture the number
anything between brackets is a character class. So you have space and non-spacecharacters in the class...
So regexp should be
must be Size:\\s+(\\S+)$
still not safe so make it Size:\\s+(\\d+)$
$ is end of line, so you will only grab them at the end of a line.
to get all, remove end of line assertion.
The captured objects are now in the sub-match part of the stringsearcher. Expose.
