How to extract relative position of point in connection to another?
lazarlubomir
Forum|alt.badge.img+10
Hello,
please, I need to solve one spicy problem. I have autocad_insert entity (block reference) composed by insert point and text point (label). Distance between these two point is variable, so I need to extract relative position of text point to block insert point. Is any possibility there to extract difference in X,Y?
Thank You so much!
Lubo
Best answer by erik_jan
You should be able to do this using the ExpressionEvaluator or any other transformer that has the Arithmetic Editor.
The attribute values for the insertion and text points x and y) should be available if you expose them on the reader feature type.
Same for autocad_text_x_pos and autocad_text_y_pos
erik_jan
Forum|alt.badge.img+19
  • November 3, 2017
lazarlubomir
  • November 3, 2017
Yes, thank You so much! I solved it by non-exploding of block, then I expose X/Y of attribute label and then I used ExpressionEvaluator as You supposed to count difference between X/Y of attribute label and X/Y of insert point.
Thank You for tip!
Lubo
