How to convert obj to Cesium 3D Tiles
  • May 12, 2022
  • 251 views
limo
Forum|alt.badge.img+8
I have a 3D modell as object file. I will convert this to cesium tiles!
I tried this way:
Reader -> CoordinateSystemSetter -> Writer (Cesium 3D Tiles)
But if I import the tiles inside cesium (e.g. cesium ion) I do not get georeferencing. So the model is not display at the correct location.
Is it possbile to assign a georeference to an obj file?
limo
  • May 13, 2022
I found out normally obj files are not georeferenced.
But I can use Offsetter to add offsetts to the features coordinate. Then I can use Reprojection if necessary and the model is placed at the correct position
