Get random features from a dataset
  • September 7, 2021
  • 305 views
boubcher
Forum|alt.badge.img+11
hello there w want to extract some features from the dataset randomly
ex:
we have 300 features coming in we want to get only 160 from them randomly
we trayed to use the sample, but it did work since its working base on the N rate
Any suggestion
Thanks
Forum|alt.badge.img+39
  • September 7, 2021
You can change the sampling type to the first N features, set N to 160 and select Yes for Randomize sampling. Note that this will select 160 features out of the 300 at random but they will be in the original order.
If you want a random order, you can use a random number generator, sort by the random number then use the sampler to get the first 160
boubcher
  • September 7, 2021
Thanks
Great
boubcher
  • September 7, 2021
is there a way we could assign the sampling value to an attribute value , its taking only parameter , since this value will depend on count of the coming features
Thanks
  • September 7, 2021
Thanks
I don't think it's possible in the sampler. An alternative would be after sorting to use a counter, followed by a tester and only pass features where count < sample size
