Draw a box with four points using polygon from line builder
  • December 12, 2023
  • 54 views
jp12212
Forum|alt.badge.img+4
I'm trying to draw a box given four vertex creators, I couldn't get the polygon section to work from line builder - any tips on making this more efficient, I feel like four line builders is not the most elegant solution (although it works.)
Thank you.
DanAtSafe
Forum|alt.badge.img+21
  • December 12, 2023
@jp12212​ Use the VertexCreators in sequence. The first will have the "Replace with Point" mode, the last three "Add Point". Then use a LineCloser to add a segment from the last vertex to the first, making a polygon.
jp12212
  • December 12, 2023
thank you.
