DOMAIN FIELD EXPORT - via Esri SDE database
  • March 19, 2020
  • 135 views
Hi guys,
I noticed that question severl times, but never find out any final solution, taht will work for me.
I have a database, with a lot of attributes in domain field. Is there any option to export those coded values with fme?
Thanks in advance.
Miha
@miharobar You need to extract the domains and subtypes from an Esri Geodatabase XML Workspace document using the FME XML reader, as described in the article: Geodatabase XML Workspace Document Schema Reader
