Dissolving overlapping polygons
  • October 23, 2015
  • 110 views
We're trying to disolve overlapping polygon features but only if the overlap area is larger than set amount. The features are buffered lines and we only want to dissolve those that share an underlying line segment. The ones that are perpundicular have to be excluded. Is it possible to put a predicate on a dissolver? Or is there any method possible? Thanks in advance,
Tom
Best answer by david_r
Hi
My suggestion is to use an AreaOnAreaOverlayer and specify a list name. For each output area where "_overlaps" > 1, calculate and test the area. If your area is larger than your threshold, explode the list to retrieve the IDs of the overlapping polygons, these are the ones you want to dissolve. These IDs you can use to filter the input polygons (FeatureMerger) before sending them to the Dissolver. Something like this:
Before
After
David
  • October 23, 2015
Hi
Before
After
David
  • November 27, 2015
david_r wrote:
Hi
Before
After
David
@david_r Sorry for the late respons but thanks for the help!
