creating a data dictionary in FME?
I have different councils Pipe material list with a specific example of say Copper – which different council has a different way to define it.. say for example one council called it “CU”, other council calls it “COP” and some other councils call it with some other name…however, the material is the same…and in general we want to define a common name for it..... say "Copper"? Can we create a data dictionary in FME?...which can identify and recognize the correct name and replace it with a generic name?
Best answer by jdh
I would probably do this as a mapping table.
Have an excel or csv file with two columns the OriginalName and the CommonName and then use a DatabaseJoiner to attach the common name as an attribute.
This way the "dictionary" can be maintained without any edits to the FME workspace.
Ex.OriginalNameCommonNameCUCopperCOPCopperFEIronIRIron
You would also be able to handle any unjoined features, where the council name is not in the dictionary. Whereas the StringPairReplacer option would just pass those features through untouched.
umapper1
Forum|alt.badge.img+5
  • June 2, 2020
I’m not sure about a dictionary but you can use conditional statements in the attributecreator transformer to assign a common name to all features that match your search criteria.
  • June 2, 2020
Hi @ppp19, if all the possible aliases of "Copper" are known, the StringPairReplacer would be available to convert every alias to "Copper".
jdh
Forum|alt.badge.img+28
  • June 2, 2020
I agree with this approach. Preserves the original data and creates the alias field.
  • June 3, 2020
Hi @jdh, this DatabaseJoiner worked well for me...However, I have few raws in my csv file which is blank (having no material name in OriginalName column as you described)...and don't know how to map those rows with common name...because those raws showing unjoined in Databasejoiner.
Regards,
  • June 3, 2020
Regards,
Hi @jdh, please ignore my previous reply...I have now figured out my blank raw issue.
Regards,
  • June 3, 2020
Hi @takashi, the above idea of databasejoiner worked for me..thanks for your time to reply me on this issue.
Regards,
  • June 3, 2020
Hi @umapper1, the below idea of databasejoiner worked for me.. thanks for your time to reply me on this issue.
Regards,
  • June 9, 2020
Regards,
Hi@jdh,
Hi I have created an excel sheet with adding attribute values for Material and used the DatbaseJoiner function of FME to Map column A with Column B and C as per our previous discussion. Well, it works good for all other material but it is showing unjoined only for MDPE, AK and mPVC. I did everything to rejoin this mapping but it is not taking only these 3 material names in consideration and shows unjoined in FME.... :(
Any reason you can see here?
Regards,
jdh
  • June 9, 2020
ppp19 wrote:
Hi@jdh,
Regards,
The first thing to do is check of there are any white spaces in either the csv or the actual council data. 'MDPE ' is not the same as 'MDPE'. If it's in the data an AttributeTrimmer can strip the extraneous white space.
  • June 10, 2020
Hi @jdh...it worked well!!!...Thanks for your help... :)
Regards
