CoordinateExtractor vs @XValue()/@YValue() for multi(line/surface)
p.jeremie
I noticed the following behavior.
I created two shapefiles for this test : line.shp and surface.shp
Both contain several feature including one with multiparts (multiline and multisurface).
When using CoordinateExtractor with mode Specify Coordinate + index=0, I get in the _x and _y attributes the first point of the first part of line/surface.
I assumed I would get the same with @XValue() and @YValue() but it is not the case for the multiparts features.
For those I get a point far far away from the feature, with integer values for X and Y.
Anybody knows why ? Is it a normal behavior ?
Tested on FME 2018.1 and 2019.0, see enclosed test workspace on FME 2019.
Best answer by fmelizard
Hi @p.jeremie The CoordinateExtractor is hiding the first coordinate for aggregates. I don't know why the @XValue() and @YValue() don't also skip the first vertex. Y is the number of coordinates in the first element. For multipart polygons, X=4; for lines, X =2.
Forum|alt.badge.img+62
It doesn't seem like normal behaviour to me (it's also happening in FME 2020 by the way). I would recommend sending this in to Safe's support team.
The easy workaround is to use the CooridnateExtractor of course.
Forum|alt.badge.img+46
  • April 22, 2020
@Evaluate(@Coordinate(x,0)) & @Evaluate(@Coordinate(y,0) give the same integer figures for the multiparts.
Interestingly @Evaluate(@Coordinate(x,1)) & @Evaluate(@Coordinate(y,1)) return the correct first coordinate for the multipart features
itay
Forum|alt.badge.img+18
  • April 22, 2020
Apparently de-aggregating the multi feature helps....
p.jeremie
  • April 22, 2020
I filed a report. Case number C153869.
In the meantime yes I will use CoordinateExtractor.
p.jeremie
  • April 22, 2020
Indeed, it's weird...
fmelizard
Forum|alt.badge.img+21
  • April 23, 2020
p.jeremie
  • April 23, 2020
Hi @danatsafe. Indeed, it makes sense now.
FYI I filed a report. Case number C153869.
