Avoiding overlaps and gaps when buffering line segments to polygons
  • September 16, 2025
  • 134 views
jonvelco
I have line segments (vertex only a beginning and end) and want to create polygons for each (including their attributes).  The line segments represent a span between utility structures in a right of way. The goal is create the polygon geometry per span and calculate the acreage in each.
The Bufferer works great when the line segments are straight, but when a turn is introduced, I get slivers and overlaps as seen in this screenshot:
Notice the overlaps and slivers where the line turns
Bufferer Parameters:
Bufferer parameters
To visualize what I’m trying to create - here is a mock up of where I want the polygons split (red lines were drawn in by me and the green polygon is just a buffer of the dissolved line segments).  The centerline represents the spans.
Red lines = where I want the polygons split
Doesn't sound too crazy but it’s kicking by butt at the moment.  Any idea or suggestions?
Best answer by nielsgerrits
I tried to solve this by generating cutting lines from the vertices at the end of the points using the NeighborFinder. Attached workspace.
nielsgerrits
Forum|alt.badge.img+62
  • September 17, 2025
jonvelco
@nielsgerrits Perfect!  I was able to get the results I was looking for with your workbench.  Thanks again!
