ArcGISOnlineConnector - Requires an output_tag argument when multiple output ports exist error
  • November 14, 2025
  • 43 views
ash.barnes
Forum|alt.badge.img+3
Hey all,
Currently having an issue using the ArcGIS Connector when using FME Flow (or Form without Feature Caching / Counting on), receiving the following error below. Full log posted below the error message.
The outcome I am looking to produce is to update a CSV file hosted on an Enterprise Platform.
This does run with form with feature caching on.
Any help would be much appreciated.
Thanks.
Ash
135 2025-11-14 17:25:19 | Message Type: fme::internal::_v0::py::Exception
136 2025-11-14 17:25:19 | Python Exception <TypeError>: Call to pyoutput() requires an output_tag argument when multiple output ports exist
137 2025-11-14 17:25:19 | Error encountered while calling method `input'
138 2025-11-14 17:25:19 | ArcGISOnlineConnector_2_CALLER (PythonFactory): PythonFactory failed to process feature
2025-11-14 17:24:59|   0.0|  0.0|INFORM|Current FME version: FME 2024.2.1.0 (20241202 - Build 24801 - WIN64)
2025-11-14 17:24:59| 0.0| 0.0|INFORM|System Time: 20251114172459 UTC
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Workspace was last saved in FME version: FME 2024.2.1.0 (20241202 - Build 24801 - WIN64)
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME_HOME is 'C:\Program Files\FMEFlow\Server\fme\'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Engine (node locked-crc)
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Serial Number: SAFE
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Machine host name is: azuksfmeengp02
2025-11-14 17:24:59| 0.0| 0.0|INFORM|OS Locale Name : en_US
2025-11-14 17:24:59| 0.0| 0.0|INFORM|OS Locale Encoding : windows-1252
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Process Encoding : UTF-8
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME API version: '4.0 20240212'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: FME_BASE is 'no'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: FME_MF_DIR is '\\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\repositories\30533600_HS2PostEx\305336-00_HS2_PostEx_BarcodesUpdate/'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: FME_MF_NAME is '305336-00_HS2_PostEx_BarcodesUpdate.fmw'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: FME_PRODUCT_NAME is 'FME(R) 2024.2.1.0'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Operating System: Microsoft Windows Server 2022 64-bit (Build 20348)
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Platform: WIN64
2025-11-14 17:24:59| 0.0| 0.0|INFORM|System Status: 57.06 GB of disk space available in the FME temporary folder (C:\Users\SVC-FM~1\AppData\Local\Temp\fmeengines\azuksfmeengp02_Engine1)
2025-11-14 17:24:59| 0.0| 0.0|INFORM|System Status: 16.00 GB of physical memory available
2025-11-14 17:24:59| 0.0| 0.0|INFORM|System Status: 64.00 GB of virtual memory available
2025-11-14 17:24:59| 0.0| 0.0|INFORM|START - ProcessID: 16308, peak process memory usage: 76916 kB, current process memory usage: 76916 kB
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: Command line arguments are `fme' `30533600_HS2PostEx\305336-00_HS2_PostEx_BarcodesUpdate\305336-00_HS2_PostEx_BarcodesUpdate.fmw' `--FME_SERVER_REQUEST_URI' `https://fme-uk.arup.com/fmejobsubmitter/30533600_HS2PostEx/305336-00_HS2_PostEx_BarcodesUpdate.fmw' `--FME_SERVER_PORT' `7071' `--FME_SHAREDRESOURCE_DATA' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata/resources/data/' `--FME_DATA_REPOSITORY' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata/resources/system/temp/upload/' `--FME_SECURITY_USER' `Ash.Barnes' `--FME_SERVER_ROOT' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata' `--FME_SERVER_REQUEST_HEADERS' `{"remote-addr":"10.126.117.6","host":"fme-uk.arup.com"}' `--FME_ENGINE' `azuksfmeengp02_Engine1' `-LOG_FILENAME' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata/resources/logs/engine/current/jobs\4000\job_4032.log' `--SourceDataset_GEODATABASE_SDE_3' `HS2<space>POST-EX<space>REF<space><openparen>read-only<closeparen>' `--FME_SHAREDRESOURCE_ENGINE' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata/resources/engine/' `--FME_SERVER_REQUEST_PARAMETERS' `***' `--FME_JOB_CONTEXT' `context-id-de941933-eb23-41e9-a17f-dfd9e6066723' `--UK_GIS' `//glodfs101.global.arup.com/GIS/UK/' `--FME_SERVER_REQUEST_METHOD' `POST' `--LondonInternalDrive' `\\glodfs101.global.arup.com\London/' `-FME_SHARED_RESOURCE_DIR' `\\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\repositories\30533600_HS2PostEx\305336-00_HS2_PostEx_BarcodesUpdate' `--FME_SERVER_WEB_URL' `https://fme-uk.arup.com:443' `--FME_SHAREDRESOURCE_LOG' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata/resources/logs/' `--FME_SHAREDRESOURCE_TEMP' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata/resources/temp/' `--FME_JOB_ID' `4032' `--FME_ENGINE_CONFIG_DIR' `C:\Program Files\FMEFlow\Server\' `--FME_SHAREDRESOURCE_DASHBOARD' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata/resources/dashboards/' `--FME_MF_NAME' `305336-00_HS2_PostEx_BarcodesUpdate.fmw' `--GlobalGISDrive' `\\global\gis/' `--SODP' `//global/gis/UK/603000/60303502 - Sewer Overflow Data Portal/Incoming/UCSO/DocumentLibrary/' `-FME_ENGINE_MEMORY_REDLINE' `0.5' `--FME_SHAREDRESOURCE_BACKUP' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata/resources/backups/' `--FME_SHAREDRESOURCE_SYSTEM' `//azuksfmecorepsa02.file.core.windows.net/uksfmeserverpdata02/fmeflowdata/resources/system/' `--DestDataset_XLSXW' `$(GlobalGISDrive)\UK\305000\305336-00_HS2_PostEx\Outgoing\Issued\2025_06_19 Duplicate Barcodes\DuplicateBarcodes.xlsx' `--FME_SERVER_RUNTIME_USER' `Ash.Barnes' `--FME_SECURITY_ROLES' `["user:Ash.Barnes","App_FME_UK_PROD_Author"]' `--FME_SERVER_RUNTIME_USER_ID' `01a41dd1-603a-4e50-9950-9fcd7aedde0e' `--GlobalInternalDrive' `\\glodfs101.global.arup.com\Americas/' `--FME_SERVER_HOST' `azuksfmecorep02'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: Connection Storage: 'azuksfmecorep02'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Shared folders for formats are : C:\Program Files\FMEFlow\Server\fme\datasources;\\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\resources\engine\Formats;C:\Users\SVC-FME-PROD\Documents\FME\Formats
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Shared folders for transformers are : \\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\resources\engine\Packages\24801-win64\transformers;C:\Users\SVC-FME-PROD\AppData\Roaming\Safe Software\FME\Packages\24801-win64\transformers;C:\Program Files\FMEFlow\Server\fme\transformers;\\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\repositories\30533600_HS2PostEx\305336-00_HS2_PostEx_BarcodesUpdate;\\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\resources\engine\Transformers
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Shared folders for coordinate systems are : \\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\resources\engine\CoordinateSystems;C:\Users\SVC-FME-PROD\Documents\FME\CoordinateSystems
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Shared folders for coordinate system exceptions are : \\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\resources\engine\CoordinateSystemExceptions;C:\Users\SVC-FME-PROD\Documents\FME\CoordinateSystemExceptions
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Shared folders for coordinate system grid overrides are : \\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\resources\engine\CoordinateSystemGridOverrides;C:\Users\SVC-FME-PROD\Documents\FME\CoordinateSystemGridOverrides
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Shared folders for CS-MAP transformation exceptions are : \\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\resources\engine\CsmapTransformationExceptions;C:\Users\SVC-FME-PROD\Documents\FME\CsmapTransformationExceptions
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Shared folders for transformer categories are : C:\Users\SVC-FME-PROD\Documents\FME\TransformerCategories
2025-11-14 17:24:59| 0.0| 0.0|INFORM|Mapping File Identifier is: 30533600_HS2PostExBarcodeUpdate
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: No destination coordinate system set
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: Current working folder is `\\azuksfmecorepsa02.file.core.windows.net\uksfmeserverpdata02\fmeflowdata\repositories'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: Temporary folder is in the system location `C:\Users\SVC-FM~1\AppData\Local\Temp\fmeengines\azuksfmeengp02_Engine1'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: Cache folder is 'C:\Users\SVC-FM~1\AppData\Local\Temp\fmeengines\azuksfmeengp02_Engine1'
2025-11-14 17:24:59| 0.0| 0.0|INFORM|FME Configuration: FME_HOME is `C:\Program Files\FMEFlow\Server\fme\'
2025-11-14 17:24:59| 0.1| 0.1|INFORM|FME Configuration: Start freeing memory when the process exceeds 48.00 GB
2025-11-14 17:24:59| 0.1| 0.0|INFORM|FME Configuration: Stop freeing memory when the process is below 36.00 GB
2025-11-14 17:24:59| 0.2| 0.1|INFORM|Creating writer for format:
2025-11-14 17:24:59| 0.2| 0.0|INFORM|Creating reader for format:
2025-11-14 17:24:59| 0.2| 0.0|INFORM|MULTI_READER(MULTI_READER): Will fail with first member reader failure
2025-11-14 17:24:59| 0.2| 0.0|INFORM|MULTI_READER(MULTI_READER): Adding GEODATABASE_SDE Reader with keyword GEODATABASE_SDE_2
2025-11-14 17:24:59| 0.2| 0.0|INFORM|Using Multi Reader with keyword `MULTI_READER' to read multiple datasets
2025-11-14 17:25:00| 0.7| 0.5|INFORM|FME Configuration: Using connection values from 'HS2 POST-EX REF (read-only)' for GEODATABASE_SDE_2
2025-11-14 17:25:00| 0.7| 0.0|INFORM|Creating reader for format: Esri Geodatabase (ArcSDE Geodb)
2025-11-14 17:25:00| 0.9| 0.2|INFORM|Trying to find a DYNAMIC plugin for reader named `GEODATABASE_SDE'
2025-11-14 17:25:00| 0.9| 0.0|WARN |FME Configuration: Maximum of 200 feature(s) will be read starting from feature number 1
2025-11-14 17:25:00| 0.9| 0.0|INFORM|Loaded module 'GEODATABASE_SDE' from file 'C:\Program Files\FMEFlow\Server\fme\plugins/..\geodatabase9.dll'
2025-11-14 17:25:00| 0.9| 0.0|INFORM|FME API version of module '..\geodatabase9' matches current internal version (4.0 20240212)
2025-11-14 17:25:00| 0.9| 0.0|INFORM|Opening the Esri Geodatabase reader
2025-11-14 17:25:00| 0.9| 0.0|INFORM|An ArcGIS license is already checked out. The product checked out is 'Advanced'
2025-11-14 17:25:01| 0.9| 0.0|INFORM|Installed ArcGIS version is '3.3.2'
2025-11-14 17:25:01| 0.9| 0.0|WARN |User name and password overrides are not supported with Windows Authentication on connection file '\\global\gis\UK\305000\305336-00_HS2_PostEx\Data\SDE Connections\GBR_30533600_PostEx_Ref.sde'. Credential overrides will be ignored
2025-11-14 17:25:02| 1.1| 0.2|INFORM|Connection made to server 'AZPSQLGISP01' for dataset 'GBR_30533600_PostEx_Ref' (transactional version 'dbo.DEFAULT') using Operating System's current user
2025-11-14 17:25:02| 1.1| 0.0|INFORM|ArcSDE release: '11.2'. Underlying database: 'SQL Server'
2025-11-14 17:25:02| 1.1| 0.0|INFORM|GEODATABASE_SDE_2 Reader: Using Enhanced geometry
2025-11-14 17:25:02| 1.1| 0.0|INFORM|All network information will be ignored. As a result, edges will be treated as polyline features and junctions will be treated as point features
2025-11-14 17:25:02| 1.1| 0.0|INFORM|All relationship information will be ignored. As a result, simple relationships will not be read, and attributed relationships will be read as tables
2025-11-14 17:25:02| 1.1| 0.0|INFORM|GEODATABASE_SDE reader: Creating bulk features from individual features
2025-11-14 17:25:02| 1.1| 0.0|INFORM|Using MultiWriter with keyword `PRIMARY_DEST' to output data (ID_ATTRIBUTE is `multi_writer_id')
2025-11-14 17:25:02| 1.1| 0.0|INFORM|Writer output will be ordered by value of multi_writer_id
2025-11-14 17:25:02| 1.1| 0.0|INFORM|Loaded module 'DuplicateRemoverFactory' from file 'C:\Program Files\FMEFlow\Server\fme\plugins/DuplicateRemoverFactory.dll'
2025-11-14 17:25:02| 1.1| 0.0|INFORM|FME API version of module 'DuplicateRemoverFactory' matches current internal version (4.0 20240212)
2025-11-14 17:25:02| 1.1| 0.0|INFORM|Loaded module 'AttributeKeeperFactory' from file 'C:\Program Files\FMEFlow\Server\fme\plugins/AttributeKeeperFactory.dll'
2025-11-14 17:25:02| 1.1| 0.0|INFORM|FME API version of module 'AttributeKeeperFactory' matches current internal version (4.0 20240212)
2025-11-14 17:25:02| 1.1| 0.0|INFORM|Loaded module 'PythonFactory' from file 'C:\Program Files\FMEFlow\Server\fme\plugins/PythonFactory.dll'
2025-11-14 17:25:02| 1.1| 0.0|INFORM|FME API version of module 'PythonFactory' matches current internal version (4.0 20240212)
2025-11-14 17:25:02| 1.1| 0.0|INFORM|Using Python interpreter from `C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python311.dll' with PYTHONHOME `C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3'
2025-11-14 17:25:02| 1.1| 0.0|INFORM|Python version 3.11 loaded successfully
2025-11-14 17:25:03| 1.4| 0.3|INFORM|ArcGIS for the Python interpreter initialized in 1.3865437 seconds
2025-11-14 17:25:05| 1.6| 0.2|INFORM|Reading feature type 'PEX.HER_ARP_HSTWO_PostExCatalogSurvey_Tbl'
2025-11-14 17:25:05| 1.7| 0.1|INFORM|Tester (TestFactory): Splitting bulk features into individual features
2025-11-14 17:25:05| 1.7| 0.0|INFORM|Tester_2 (TestFactory): Splitting bulk features into individual features
2025-11-14 17:25:05| 1.7| 0.0|INFORM|Creating writer for format:
2025-11-14 17:25:05| 1.7| 0.0|INFORM|Using MultiWriter with keyword `FeatureWriter' to output data (ID_ATTRIBUTE is `multi_writer_id')
2025-11-14 17:25:05| 1.7| 0.0|INFORM|Creating writer for format: CSV (Comma Separated Value)
2025-11-14 17:25:05| 1.9| 0.2|INFORM|Trying to find a DYNAMIC plugin for writer named `CSV2'
2025-11-14 17:25:05| 1.9| 0.0|INFORM|Loaded module 'CSV2' from file 'C:\Program Files\FMEFlow\Server\fme\plugins/CSV2.dll'
2025-11-14 17:25:05| 1.9| 0.0|INFORM|FME API version of module 'CSV2' matches current internal version (4.0 20240212)
2025-11-14 17:25:05| 1.9| 0.0|INFORM|FME Configuration: No destination coordinate system set
2025-11-14 17:25:05| 1.9| 0.0|INFORM|Writer `FeatureWriter_0' of type `CSV2' using group definition keyword `FeatureWriter_0_DEF'
2025-11-14 17:25:06| 2.0| 0.1|INFORM|CSV writer: Directive '_EXTENSION' has the value 'csv'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_DELIMITER' has the value ','
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_ENCODING' has the value 'UTF-8'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_WRITE_BOM_FOR_UNICODE' has the value 'Yes'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_QUALIFY_FIELD_NAMES' has the value 'if_needed'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_QUALIFY_FIELD_VALUES' has the value 'if_needed'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_TREAT_EMBEDDED_FIELD_QUALIFIERS_AS_UNSAFE' has the value 'Yes'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_FIELD_QUALIFIER_CHARACTER' has the value '"'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_FIELD_QUALIFIER_ESCAPE_CHARACTER' has the value '"'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_ROW_TERMINATION' has the value 'System'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_WRITE_SCHEMA_FILE' has the value 'NO'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Opening dataset '$(GlobalGISDrive)\UK\305000\305336-00_HS2_PostEx\Workspaces\GBR_30533624_PostEx_AssetLabelling\Survey123\Barcodes.csv'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|Closing the Esri Geodatabase reader
2025-11-14 17:25:06| 2.0| 0.0|INFORM|MULTI_READER(MULTI_READER): Done reading 200 features from 1 readers
2025-11-14 17:25:06| 2.0| 0.0|INFORM|Emptying factory pipeline
2025-11-14 17:25:06| 2.0| 0.0|STATS |Router and Unexpected Input Remover (RoutingFactory): Tested 200 input feature(s), wrote 200 output feature(s): 200 matched merge filters, 200 were routed to output, 0 could not be routed.
2025-11-14 17:25:06| 2.0| 0.0|STATS |PEX.HER_ARP_HSTWO_PostExCatalogSurvey_Tbl_GEODATABASE_SDE_2 Splitter (TeeFactory): Cloned 200 input feature(s) into 400 output feature(s)
2025-11-14 17:25:06| 2.0| 0.0|STATS |Tester (TestFactory): Tested 200 input feature(s) -- 197 feature(s) passed and 3 feature(s) failed
2025-11-14 17:25:06| 2.0| 0.0|STATS |AttributeValueMapper (TeeFactory): Cloned 3 input feature(s) into 3 output feature(s)
2025-11-14 17:25:06| 2.0| 0.0|STATS |Tester_3 (TestFactory): Tested 3 input feature(s) -- 3 feature(s) passed and 0 feature(s) failed
2025-11-14 17:25:06| 2.0| 0.0|INFORM|Sorter (SortFactory): Starting sorting 197 feature(s)
2025-11-14 17:25:06| 2.0| 0.0|INFORM|Sorter (SortFactory): Done sorting 197 feature(s)
2025-11-14 17:25:06| 2.0| 0.0|INFORM|Creating writer for format:
2025-11-14 17:25:06| 2.0| 0.0|INFORM|Using MultiWriter with keyword `FeatureWriter_2' to output data (ID_ATTRIBUTE is `multi_writer_id')
2025-11-14 17:25:06| 2.0| 0.0|INFORM|Creating writer for format: CSV (Comma Separated Value)
2025-11-14 17:25:06| 2.0| 0.0|INFORM|Trying to find a DYNAMIC plugin for writer named `CSV2'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|FME Configuration: No destination coordinate system set
2025-11-14 17:25:06| 2.0| 0.0|INFORM|Writer `FeatureWriter_2_0' of type `CSV2' using group definition keyword `FeatureWriter_2_0_DEF'
2025-11-14 17:25:06| 2.0| 0.0|INFORM|CSV writer: Directive '_EXTENSION' has the value 'csv'
2025-11-14 17:25:07| 2.0| 0.0|INFORM|CSV writer: Directive '_WRITE_SCHEMA_FILE' has the value 'NO'
2025-11-14 17:25:07| 2.0| 0.0|INFORM|CSV writer: Opening dataset '$(GlobalGISDrive)\UK\305000\305336-00_HS2_PostEx\Workspaces\GBR_30533624_PostEx_AssetLabelling\Survey123\RecordTableLookUp.csv'
2025-11-14 17:25:07| 2.0| 0.0|STATS |Sorter (SortFactory): Finished sorting a total of 197 features.
2025-11-14 17:25:07| 2.0| 0.0|INFORM|=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2025-11-14 17:25:07| 2.0| 0.0|INFORM|Feature output statistics for `CSV2' writer using keyword `FeatureWriter_2_0':
2025-11-14 17:25:07| 2.0| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2025-11-14 17:25:07| 2.0| 0.0|STATS | Features Written
2025-11-14 17:25:07| 2.0| 0.0|STATS |RecordTableLookUp 196
2025-11-14 17:25:07| 2.0| 0.0|STATS |==============================================================================
2025-11-14 17:25:07| 2.0| 0.0|STATS |Total Features Written 196
2025-11-14 17:25:19| 3.2| 1.2|INFORM|Connection Storage: Updating connection 'ash.barnes Esri ArcGIS Enterprise OAuth (Template) (safe.esri-agol)'
2025-11-14 17:25:19| 3.2| 0.0|INFORM|ArcGISOnlineConnector_2: Updating file content of item with id '3782f685218041228147f345bb6d3573'
2025-11-14 17:25:19| 3.2| 0.0|INFORM|ArcGISOnlineConnector_2: Action status: 'uploading part 1 of file'
2025-11-14 17:25:19| 3.3| 0.1|ERROR |Message Type: fme::internal::_v0::py::Exception
2025-11-14 17:25:19| 3.3| 0.0|ERROR |Python Exception <TypeError>: Call to pyoutput() requires an output_tag argument when multiple output ports exist
2025-11-14 17:25:19| 3.3| 0.0|ERROR |Error encountered while calling method `input'
2025-11-14 17:25:19| 3.3| 0.0|FATAL |ArcGISOnlineConnector_2_CALLER (PythonFactory): PythonFactory failed to process feature
2025-11-14 17:25:19| 3.3| 0.0|INFORM|=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2025-11-14 17:25:19| 3.3| 0.0|INFORM|Feature output statistics for `CSV2' writer using keyword `FeatureWriter_0':
2025-11-14 17:25:19| 3.3| 0.0|STATS |=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
2025-11-14 17:25:19| 3.3| 0.0|STATS | Features Written
2025-11-14 17:25:19| 3.3| 0.0|STATS |Barcodes 196
2025-11-14 17:25:19| 3.3| 0.0|STATS |==============================================================================
2025-11-14 17:25:19| 3.3| 0.0|STATS |Total Features Written 196
2025-11-14 17:25:19| 3.3| 0.0|WARN |An error has occurred. Check the logfile above for details
2025-11-14 17:25:19| 3.3| 0.0|INFORM|Translation FAILED with 4 error(s) and 3 warning(s) (0 feature(s) output)
2025-11-14 17:25:19| 3.3| 0.0|INFORM|FME Session Duration: 20.6 seconds. (CPU: 1.8s user, 1.5s system)
2025-11-14 17:25:19| 3.3| 0.0|INFORM|END - ProcessID: 16308, peak process memory usage: 177840 kB, current process memory usage: 146608 kB
j.botterill
Forum|alt.badge.img+54
  • November 17, 2025
Check under Tools > FME options and find “FME Packages”
You might be able to ‘upgrade’ ArcGISOnlineConnector
 https://hub.safe.com/publishers/safe/packages/esri-agol
Down the bottom, hit upgrade to get something newer than 3.13 release which has a fix you’re probably looking for
https://support.safe.com/hc/en-us/articles/25407474895629-How-to-Create-an-ArcGIS-Online-Web-Connection-OAuth-2-0
  • As of FME 2024.0, support for Esri ArcGIS Online (AGOL), ArcGIS Enterprise Portal, and ArcGIS Server Feature Services has transitioned to a unified approach using the new Esri ArcGIS Feature Service (Connector).
ash.barnes
  • November 24, 2025
Thanks for the response!
I did check the version of ArcGISConnector I had and was the latest version. Turned out the issue I was having was not connecting another transformer to the output of the ArcGISConnector!
Hopefully useful if anyone else has that issue.
Thanks again.
