Hull Accumulator - what decision making is it doing?
  • October 21, 2024
  • 106 views
p_c_20
Forum|alt.badge.img+9
I’m looking at an area of survey points that can be divided into east and west areas by grouping with an attribute value. I have used Hull Accumulator to draw polygons around a) the whole area (light purple) and b) the two subdivisions (darker purple). The point population remains the same overall, but I get different external boundaries in places, when I was expecting the same. Alpha = 0.
What would be useful is any description about how the transformer makes its drawing choices.
I also end up with a donut hole. Again, am trying to understand how this occurs, as I assumed the transformer would create an external boundary only.
Many thanks
Best answer by nielsgerrits
Have you read the documentation?
Concave hulls and alpha values
Concave hulls vary in shape. They are calculated by first triangulating the dataset, then measuring the circumradius of the resulting triangles (the radius of a circle that touches all three points of the triangle). Triangles that are larger than the specified Alpha Value are discarded, and the rest are dissolved to form the hull. Measurements are in ground units.
If the Alpha Value is explicitly specified, it is used for the calculation. If it is zero (0) or not specified, the alpha is approximated as the smallest value that produces a single area. If the alpha is too small it may return a null geometry. Larger numbers generally produce larger areas, and a large enough alpha value produces the same result as a convex hull.
See Examples below to see the effect of varying the Alpha Value.
Geometries that are farther away than Alpha Value from the rest of the geometries may be discarded if they do not constitute a valid area on their own.
Concave hull generation works best with points, but line and area geometries will be accepted and converted to points if input.
nielsgerrits
Forum|alt.badge.img+62
  • October 21, 2024
s.jager
Forum|alt.badge.img+22
  • October 21, 2024
I thought that was pretty well described in the HullAccumulator documentation. Look at the examples, that shows a hole being created as well. It explains how it achieves the results:
Btw: using a DonutHoleExtractor it’s easy to remove the hole.
Edit: Niels posted while I was typing. Sorry, didn’t mean to duplicate answers….
nielsgerrits
...great minds think alike… is what I think when this happens to me :-)
