yes I did but the osm donloader stop at the tester inside the bookmark "Make destination folder; Validate specified extents" so I suppose that something happens here
The feature is rejected because it doesn't satisfy all conditions from the tester.
The feature is passed through the Rejected port, so you can inspect it and determine why it was rejected.
If you cannot tell from the rejected feature, you can make a copy of the tester, and test on one condition at a time to find out which condition triggers the rejection.
I tried to run the wb and for some municipalities it works for the the ones that not work I tried to use the QGIS plugin and I'm able to download the data so something happens in the custom transformer
