I have serveral different directories within one directory that have TAB files (of point, line, and polygon geometry type) that I would like to merge and convert to SHP by there unique name. For example:
\\\\one\\test.TAB
\\\\one\\test2.TAB
\\\\one\\test3.TAB
\\\\two\\test.TAB
\\\\two\\test2.TAB
\\\\two\\test3.TAB
What I want is for the output directory is, all the same name files to be merged and converfted to ESRI SHP, e.g.
\\\\export\\test.SHP
\\\\export\\test2.SHP
\\\\export\\test3.SHP
I defined my TAB reader to the TAB directory/sub directory as Single Merged Feature Type. For my SHP writer I defined my output directory, however I'm not sure where to go from here since it is asking for a particular geometry type and the input TAB files are of different geometry type being point, line, and polygon. I guessing there is some automated way of using one reader and one writer instead of creating seperate readers and writers for each unique input dataset?
Thank you
