I understood that Arcpy is Additional Python module for FME Server
To access Arcpy module I need to follow two steps
1. Obtaining the Python Module2. Uploading the Python Module
I am a beginner for Python, so I am not able understand Obtaining the Python module.
My doubt is which package I need to download for Arcpy and run in command prompt or where its available those files in my machine if I installed everything correct.
Uploading the Python Module for Arcpy which files i need to upload into FME Server "Engine\\Plugins\\python".
Kindly help me to run Arcpy in FME Server.
Thanks in Advance
Venu
Hi @venu,
I believe the ArcPy module is slightly different in the fact that you cannot use pip to install it so the steps outlined in the help doc under 'Obtaining/Uploading the python module' are not relevant here.
Instead for any workspace that needs to use ArcPy, as long as you have a licensed install of ArcGIS on the same machine as your FME Server, just set the Python Compatibility parameter in FME Workbench to the same one used by the ESRI client before it is published to FME Server.
