I'm trying to use FME 2025.0 to create a GeoPackage tiles file. It should contain a few Norwegian raster products, such as N50, N100 and N250. The idea is to mimic the properties of the Swedish product “Topografisk webbkarta Nedladdning, raster”, in the sense that the Swedish product contains a single table in the gpkg file and it shows different raster data at different scales. I am having trouble recreating this with the Norwegian products. I´m stuck at creating a separate tables for each data set or a single table that only contains a single data set. This use case is not discussed at, for example, https://support.safe.com/hc/en-us/articles/37417604217357-Creating-OGC-Compliant-GeoPackage-Files#h_01JXXGG7338W04GD0DRBY7VJCV. Any help appreciated.
Norwegian products: https://www.kartverket.no/en/on-land/kart/kartbilder
Swedish product: https://www.lantmateriet.se/sv/geodata/vara-produkter/produktlista/topografisk-webbkarta-nedladdning-raster/
Magnus
