Error Writing Multipart Geometries to ArcGIS Online with New Esri ArcGIS Feature Service Writer
  • September 25, 2025
  • 8 replies
  • 292 views
paul_m
Forum|alt.badge.img+20
We have multiple workspaces that write to ArcGIS Online with multipart geometries. The old ARCGISONLINEFEATURES writer works and correctly writes the geometries. The new (2025) Esri ArcGIS Feature Service Writer returns an error rejecting the features and the following warning:
ArcGISFeatureServiceWriter: INSERT error for a feature in Project Stats by State. The error code from the server was '1000' and the message was 'Adding/updating geometries that result in SQL GeometryCollections is currently not supported (SQL Server performance).'
Using a Deaggregator seems to fix this in most cases. However, we want to retain the multipart geometries. In other cases, I see a similar warning and the following error after using a Deaggregator:
ArcGISFeatureServiceWriter: INSERT error for a feature in Terracon Offices Closest Areas. The error code from the server was '1000' and the message was 'Data is Null. This method or property cannot be called on Null values.'
I’ve tried a NullAttributeMapper and only writing a single column that I know has 0 NULLs and see the same error and warning. Has anyone ran into these issues with the new writer? If so, have you found a workaround?
Best answer by crystalwang
Hi FME Community,
For anyone experiencing issues with data being written to the wrong location, this behavior seems to be related to coordinate system differences between reference-registered data and the Feature Service’s spatial reference.
The Target WKID parameter on the writer determines the output coordinate system. The writer should automatically respect the existing Feature Service’s spatial reference during inserts and updates, but it is not doing so at this time.
To ensure your data is placed correctly, please check the feature service metadata (e.g., /FeatureServer?f=json) to identify the coordinate system used by the service, and enter that WKID value in the writer’s Target WKID parameter.
Our team is aware of this issue and is working on improving this behavior (tracked internally as FMEENGINE-88607). The expected behavior is that the Feature Service Writer automatically detects and applies the Feature Service’s spatial reference WKID from the service metadata when inserting to an existing Feature Service.
We apologize for the inconvenience, and thank you for your patience in the meantime!
crystalwang
Forum|alt.badge.img+15
  • September 30, 2025
Hi ​@paul_m,
This sounds similar to an issue we’re tracking internally as FMEENGINE-88156. If you can please submit a ticket so that our Support team can look into this further, that would be great!
We’ll be able to better assist you with more information. When submitting your ticket, please provide the following (if available/possible):
  • Details about the environment used (e.g. platform and OS version, FME Form version, any other dependencies, etc.)
  • Please provide a sample of the source data used in your workspace
  • The workspace (or sample workspace) that you are encountering issues with. Please be sure to include any required data or custom transformers needed. If, possible please send this as a template (.fmwt).
In the meantime, could you try changing the following parameter in the writer and seeing if that fixes the errors?
  • Use True Curves > No
paul_m
  • October 2, 2025
Hi ​@paul_m,
Thanks for all the info! I’ll submit a ticket. I did set True Curves to No, and the data wrote without errors, but the result is very wrong (see below). When writing the same exact data with the old ArcGIS Online writer, everything shows up in the right place with no errors.
rhatch
Participant
  • Participant
  • October 7, 2025
I’m having similar issues (data loads fine to AGOL content when using the old connector, but rotates and moves off the coast of Australia when using the new new ArcGISconnector. I’m assuming it’s a projection issue, but have had no luck fixing it. Were you able to solve this issue? Thanks!
paul_m
  • October 8, 2025
No workarounds yet, but I do have a ticket open with Safe Support regarding the issue.
markcoopersdc
I have had the same issue and have had to revert to the old feature writer.
I have also raised a ticket with Safe
paul_m
  • October 20, 2025
Quick update from communicating with Safe Support: As of now, the only workaround is using the older Esri ArcGIS Online writer. Safe’s development team is looking into the issue with the new writer.
crystalwang
  • November 12, 2025
Hi FME Community,
dsiezenga
Participant
Forum|alt.badge.img+3
  • Participant
  • November 27, 2025
I unfortunately encountered this problem recently. We just went to the new ARCGISFEATURESERVICE writer because the old AGOL writer was giving us different problems. We had good hopes this new writer would solve our problem, but now we are kinda stuck. Going back to the old writer is not an option and the new writer is giving us this exact error: ArcGISFeatureServiceWriter: INSERT error for a feature in Project Stats by State. The error code from the server was '1000' and the message was 'Adding/updating geometries that result in SQL GeometryCollections is currently not supported (SQL Server performance).'
Our translation consists of one AGOL writer with 6 hosted feature layers. If I run the entire workspace it fails on one particular layer, in this case buildings. The problem is the rest of the layers go through, but not entirely. Basically I can't run my workspace anymore. A workaround is to run each layer separetely, so that at least 5 of the 6 layers get updated entirely. The workspace is run automatically each night though, so this workaround is not the solution.
I made sure that the target WKID is the right one: it is 28992. This is set correctly in the workspace.
My question therefore is: what is the ETA on this bugfix? :)
UPDATE: I've tried the setting ‘Use True Curves → No’ and for me that solved my issue with the buildings! I can now write all of them to AGOL. Very weid, but for now my problem seems fixed by this setting.
