What versions of OGC Geopackage and SQLite does FME produce ?
  • November 11, 2022
  • 91 views
lifalin2016
Forum|alt.badge.img+39
I'm having a hard time determining which version of OGCGEOPACKAGE that FME produces ? It's not in the writer doc, so I'm asking here.
And subsequently, what version of SQLite is produced? (newest is 3.39.4 from Sep 29 this year)
As far as I can gather, the versions has been fixed since 2020.0? Is this true?
In the "gpkg_extensions" table I found a reference to "spec120", which may (or may not) indicate, that the Geopackage version is 1.2.0, a fairly old version (newest is 1.3.1).
And the real question is what extensions are the SQLite database born with? Clearly not "foreign _keys".
Can one update some template database if one needs a newer version/more extensions?
Cheers.
Best answer by evieatsafe
Hi @Lars I Nielsen​ thanks for your questions! There is more than one question here, but I'll try to answer most of what you asked to the best of my ability.
  • GeoPackage Writer produces version 1.2.0 because we are limited to the version that GDAL supports
  • We do have an internal ticket (FMEENGINE-75532) to track the upgrade of the GeoPackage Reader/Writer to 1.3.1 when support becomes available
  • The OGC GeoPackage version that we support is better documented by OGC themselves (here).
  • SQLite Writer produces version 3.36.0
  • Not sure on what extensions they are created with
Hope this helps!
evieatsafe
  • November 18, 2022
Hope this helps!
gedgg
  • December 5, 2024
has there been update on this?
Thanks
