Gml data conversion issue.
  • February 22, 2019
  • 21 views
I tried to convert a gml file to cesium 3dtiles. But the conversion didn't went well.What could be the issue.When i converted the same gml file in other software it got converted correctly.What wrong i have done in the workspace . I have attached the workspace , gml file and 3dtiles. Please help me with the issue.
nampreetatsafe
Forum|alt.badge.img+13
Hi @san,  I am having issues reading in the info.gml file into FME.  When I validate it, I get the following XML Parser error:
line:9 column:66 message:value '5e5c0ec0-6be6-4ca4-979d-9197dd5deaf5' is invalid NCName'
Can you tell me about how info.gml was created and possibly provide screenshots confirming what the feature(s) in the CityGML look like.  I can then look into it some more for you.  Thanks!
