I'm using FeatureReader as CSV format and trying to expose attribute 'fme_feature_type'. It's returning NULL or CSV. Instead it has to return FILENAME.
Any thoughts please?
Best answer by rylanatsafe
@fmeuser_gc - Try using an AttributeManager after the FeatureReader to create a new attribute that references fme_feature_type as the value. I've attached a workspace template created using FME 2017.1.2 Build 17722 that demonstrates this.
The fme_feature_type remains null, but my new attribute _fft is populated and writes out correctly (using native CSV Writer).
Hope this helps!
Edit: The display issue with fme_feature_type values in the FME Workbench Canvas and FME Data Inspector is no longer observed with FME 2018.0 Build 18240 or Newer.
