URLs Used by FME
  • June 30, 2017
  • 8 replies
  • 339 views
fmelizard
Forum|alt.badge.img+21
Can you help us complete this list of URLs used by FME?
Some of our users work in environments with limited access to the internet and need to request access to specific URLs via a proxy . We are building a list of URLs used by FME and we are asking you for more input. Below are URLs we know FME may access in typical use. Are there other URLs you think we should add to the list? We will edit this list as answers come in.
Of course, there is a multitude of web services you can connect to with FME using Web Connections and the HttpCaller transformer, and we don't want to add them all here. We are looking for URLs used by FME Workbench, standard FME readers and writers, and FME transformers.
Please note: You can, of course, run FME without any internet access at all but you won't be able to use the FME Hub or access resources on the web.
Workbench Startup
  • www.safe.com/ *
  • fmestartup.safe.com/
Help and docs:
  • docs.safe.com/
FME Hub
  • hub.safe.com:443**
  • fmehubproductionopsworks-appstorage-c2mc055amzj1.s3.amazonaws.com:443
  • cloud-cdn.safe.com
Readers and Writers
Mapzen
  • s3.amazonaws.com:443
Sentinel 2 AWS
  • sentinel-s2-l1c.s3.amazonaws.com/
SalesForce
  • login.salesforce.com:443
  • (YourOrganization).my.salesforce.com:443
Amazon DynamoDB
  • dynamodb.us-west-2.amazonaws.com:443
AWS Landsat (suggested by @1spatialdave)
  • landsat-pds.s3.amazonaws.com:443
Carto
Transformers
S3 Tranformers
  • <bucketName>.s3.amazonaws.com:443
GoogleDriveConnector
  • www.googleapis.com:443
  • accounts.google.com:443
  • accounts.google.fr:443 (may be different country suffix)
  • ssl.gstatic.com:443
  • play.google.com:443
DropboxConnector
  • dropbox.com:443
  • cfl.dropboxstatic.com:443
  • dropbox.com:443
  • api.dropboxapi.com:443
FME Server
Note: FME Server may be configured for SSL and therefore accessed via port 443
For more information on the FME Server URLs used for licensing, please visit this article.
FME Cloud
  • <name>.fmecloud.com:443
Background Maps
ArcGIS Online
  • www.arcgis.com:443
  • server.arcgisonline.com:443
  • services.arcgisonline.com/arcgis/rest/services:443
Bing
  • dev.virtualearth.net/
  • cdn.content.prod.cms.msn.com/singletile/summary/alias/experiencebyname/
  • ecn.t3.tiles.virtualearth.net/tiles/
  • ecn.t2.tiles.virtualearth.net/tiles/
  • ecn.t1.tiles.virtualearth.net/tiles/
  • ecn.t0.tiles.virtualearth.net/
Japan GSI Map
  • cyberjapandata.gsi.go.jp/
MapBox
  • api.tiles.mapbox.com/
Stamen
  • tile.stamen.com/
MapQuest
  • www.mapquestapi.com:443
Here WeGo
  • 1.base.maps.api.here.com:443
  • 2.base.maps.api.here.com:443
  • 3.base.maps.api.here.com:443
  • 4.base.maps.api.here.com:443
  • 1.aerial.maps.api.here.com:443
  • 2.aerial.maps.api.here.com:443
  • 3.aerial.maps.api.here.com:443
  • 4.aerial.maps.api.here.com:443
* forward slash indicated the URL may continue to access specific resources within that domain * * Port 443 indicated the connection is via SSL and only the root URL can be known
Best answer by davideagle
This is a great idea and crowd sourcing the details jump-starts the documentation process. I can think of serveral of our customers who will be keen followers of this list for software packaging purposes:
Reader:
AWS Landsat
Readers\\Writers
CARTO
(user_account).carto.com:443
davideagle
Forum|alt.badge.img+22
  • June 30, 2017
Reader:
AWS Landsat
Readers\\Writers
CARTO
fmelizard
  • June 30, 2017
Safe Documentation PR#78343
lars_de_vries
Forum|alt.badge.img+10
There is one more for ArcGIS Online, which allows access to the basemaps through ArcGIS Server:
https://services.arcgisonline.com/arcgis/rest/services
chriswilson
  • November 2, 2018
Hi guys,
Could someone please advise which port the background maps, or ArcGIS Online feature service lists (when using the AGOL feature layer reader) would come back to our proxy server/firewall on? I am being asked this when requesting to IT for the FME background URLs to be allowed through our firewall.
Thanks, Chris
danilo_fme
Forum|alt.badge.img+52
  • November 2, 2018
Hi guys,
Thanks, Chris
Hi @chrisw84
Please, you can check these:
ArcGIS Online
Thanks,
Danilo
chriswilson
  • December 17, 2018
Hi @chrisw84
ArcGIS Online
Thanks,
Danilo
Hi @danilo_fme,
The first one worked and the other two errored out:
  • server.arcgisonline.com:443 got no response from server
Reason:No response from server
WebMarshal Proxy was unable to reach the requested host.
Details: An existing connection was forcibly closed by the remote host.
This can be caused by:
The web server may be down
The web server may be too busy
Problems with your network connection and/or transient conditions on the Internet
Error: Invalid URL
Code: 400
rahulsharma
  • December 18, 2018
Hi @chrisw84
I think in order for work with proxies, I would highly recommend asking IT for a wildcard url exception list as follows
*.arcgisonline.com
www.arcgis.com
The reason the other URL is giving Invalid URL as you have to remove the port from the URL, in real the URL should be http://services.arcgisonline.com/arcgis/rest/services/
But again, passing it as wildcard would take care of that.
LizAtSafe
Forum|alt.badge.img+18
  • May 30, 2025
This question has been closed and redirected to the URLs Used by FME and Safe Software article which is kept up-to-date with all the current URLs.
