Open
PDF Reader: Extract Annotations
Related products:Integrations
  • April 27, 2019
  • 0 replies
  • 12 views
fer_ruiz
To speed up work, with cartographic base, you do have to draw areas on an existing cartography. Using the PDF annotations, they could be exported as well as the rest of the information. To this day you can not export the annotations created with the adobe. thank you
