Hi, On FME server I try to make a SERVER APP of an workspace. A message occurs: An unhandeled exception has occurred due to some unexpectedly omitted information, consult the web service logs for further details.
  • May 31, 2022
  • 75 views
perry
When I run the workspace locally it works fine.
When I make a server app with an other workspace I have no error.
So I think there is something wrong in the workspace.
- Where can I find 'logs for further details'?
- what went wrong
Best answer by hollyatsafe
Hi @perry​ ,
Unfortunately, you've encountered a known issue in 2021.2 that has since been resolved in FME Server 2022.0. This error will occur when the workspace configured in the app has a published parameter (of type Number or Date) that does not contain a default value. A workaround is to set a default value or change the parameter type to Text.  I'm sorry for any inconvenience.
perry
  • May 31, 2022
Found it:
I used 9 parameters in my workspace, using 4 I really need will work.
So for now it's a solution. I try to find out wat is wrong with the deleted params.
  • May 31, 2022
Hi @perry​ ,
