When searching for NTM-11 as coordsys I can not find the correct one. The one used in for instance Geoserver is mentioned here: http://epsg.io/5111
How do I translate these parameters to the right ones to include in the LocalCoordSysDefs.fme ?
Best answer by fmelizard
Otherwise the definition looks alright. If you require further assistance, please request from @DeanAtSafe and he'll take a look. Thanks!
