Automatic Rotation of 3D Objects
  • November 22, 2024
  • 0 replies
  • 30 views
offi24
Hello,
I have a question on the automatic rotation of 3D objects with FME. First I placed my 3D object on different points with the workflow explained in the following tutorial: https://support.safe.com/hc/en-us/articles/25407425765133-Creating-and-Using-Geometry-Instances. Now I want to rotate the 3D objetcs (electric poles railway) in the direction of a 2D Polyline (rail axis). Is there a possibility to rotate the 3D poles rectangular to the rail axis?
Best regards
Eric
