I have multiple FME workflows that trigger once via my directory watch. How do I avoid a SQL deadlock since they all upload to the same SQL database table?
  • April 13, 2023
  • 42 views
Forum|alt.badge.img+62
Set up job queues to route them all to one specific engine so there can only be one running at any one time?
  • April 14, 2023
Agree completely, this is probably the easiest workaround.
For a more performant solution, if necessary, have a look at your database back-end and how it supports concurrency and avoiding race conditions. For example, here are some ideas relevant to SQL Server: https://dba.stackexchange.com/a/187411
