Output WebMapTiles to one MBTiles database
  • February 21, 2023
  • 24 views
nedwaterman
Forum|alt.badge.img+9
I have been asked to convert network vector data to raster tiles using the MBTiles writer. For my specified dataset zoom levels 5 - 10 have been requested
Producing this hasn't been an issue but the problem is that the requestor wants a single MBTiles file and my workspace outputs 313, the number of rasters generated.
How can output a single MBTiles file that still contains all the zoom_level, tile_column and tile_row attribution required to use the raster files in a leaflet map?
Capture
daveatsafe
Forum|alt.badge.img+19
  • February 21, 2023
Hi @nedwaterman​,
I don't think you need the WebMapTiler transformer - the MBTiles writer will automatically tile and create the zoom levels for you, based on the settings in the Zoom Levels section of the output feature type Properties.
nedwaterman
  • February 22, 2023
Thanks Dave - this has been driving me nuts! I marvel at the power of FME...
Thanks for your help!
