Publishing to FME Server using REST
I'm trying to publish a workspace to FME Server using REST without success.
There are actually two ways of doing that:
http://docs.safe.com/fme/html/FME_Server_Documentation/Default.htm#REST_API_Doc/PUT%20repositories%20repository1.htm#_Toc279139163
http://docs.safe.com/fme/html/FME_Server_Documentation/Default.htm#REST_API_Doc/POST%20repositories%20repository.htm#_Toc279139164
Does anyone succeeded to publish a workspoace using any of those methods and if yes, can you provide a sample piece of code that is working (any language but prefered one is vbscript).
Thanks,
Larry
sigtill
Forum|alt.badge.img+24
  • July 2, 2013
I assume you have read this?:
Required Parameters
Accessing the REST interface requires a security token, which can be generated using the FME Server token service. The security token is a string of encrypted information sent between client and server to manage authentication.
For information about requesting a security token, see Token Service in the FME Server Reference Manual or FME REST Security in the FME Server Developer's Guide.
The following example is a GET request to list all available repositories, and includes the security token parameter:
httpRequest.open("GET", "/fmerest/repositories.json?token="+token_, true);
http://docs.safe.com/fme/html/FME_Server_Documentation/Default.htm#REST/REST_Required_Parameters.htm
  • July 2, 2013
Yes I read that.
I fact, we are doing lots of things using REST but we are unable to publish a workspace.
I've already a support call opened with SAFE but I was wondering if someone actually succedded.
Larry
