make constant height
2eight
Forum|alt.badge.img+3
hello
i’ want to assign one single elevation(Z) for all the vertices in a polygon based on the elevation point available inside the polygon
please suggest any ideas
nielsgerrits
Forum|alt.badge.img+62
One way to do this:
  • CoordinateExtractor to get the Z from the point as attribute.
  • SpatialRelator to merge attribute with Z from point to polygon.
  • 3DForcer to set elevation of polygon based on attribute with Z.
2eight
  • April 5, 2024
hi niels
thanks for the suggestion, that worked well, got the result
