connect fmeserver on remote host. What IP, what URL?
  • February 26, 2019
  • 5 replies
  • 39 views
I've installed fmeserver on some remote machine (VPS, linux, ubuntu, express installation). Knowing IP of this machine, how can I send remote rest api requests or at least connect it through web interface? Assuming that ip of my machine is xxx.xxx.xxx.xxx I tried to run
`xxx.xxx.xxx.xxx:80/fmeserver` to launch web interface, getting
`The requested URL /fmeserver was not found on this server. ` error.
To send rest api I tried `http://xxx.xxx.xxx.xxx/fmerest/v3/healthcheck?textResponse=false` getting The requested URL /fmerest/v3/healthcheck was not found on this server.
For installation I've followed http://docs.safe.com/fme/html/FME_Server_Documentation/Content/AdminGuide/ExpressInstallation_Linux.htm
How to build URLs to connect my fmeserver? What IP should I use? Where I do get wrong?
  • February 26, 2019
If you cannot access the server GUI on http://xxx.xxx.xxx.xxx:80/fmeserver then you need to look into that first. The API is using the same Tomcat instance as the server GUI.
First thing to check is that all daemons / services are running and that port 80 isn't blocked by the firewall anywhere. Then check all the FME Server logs.
  • February 26, 2019
If you access "http://xxx.xxx.xxx.xxx" (without '/fmeserver') via a web browser, what will happen?
  • February 27, 2019
I followed this steps
https://github.com/safesoftware/fmeserver-nginx
which led me to working fmeserver. Almost working - I could log in, I could request the licence but I couldn't see any available engines. Is it like, I need also FMEdesktop installed on remote machine? And if so, with what kind of licence?
  • February 27, 2019
So you're configuring SSL too? If yes, could you access the server GUI after the regular setup, before configuring SSL?
  • February 27, 2019
I did ssl step exactly as it is in github recipe, and yes, I can access GUI. Of course with no certification. Do I need to install fmedesktop as well on this instance?
