ArcGISOnlineConnector URL WMS upload
  • November 20, 2025
  • 15 views
jonathanklarup
I have a list of 100+ WMS services our company is using in a plugin for QGIS.
I’d like to publish these to our enterprise portal, and I thought the ArcGISOnlineConnector seemed like the right choice, due to it haven the setting:
Action: Upload
URL : WMS URL https://***.net/geoserver/dai/wms?service=WMS&request=GetCapabilities&version=1.3.0
URL Item Type: WMS ?
My error is :
ERROR |Message Type: fme::internal::_v0::py::Exception
ERROR |Python Exception <TypeError>: expected str, bytes or os.PathLike object, not NoneType
ERROR |Error encountered while calling method `input'
FATAL |ArcGISOnlineConnector_CALLER (PythonFactory): PythonFactory failed to process feature
What have I misunderstood ? Or is there a better option ?
Thanks in advance.
Best answer by donalmateer
Hey ​@jonathanklarup ,
Looks like the issue is just with the action you picked. “Upload” in the ArcGISOnlineConnector (and the Portal version) is meant for file-based content like ZIP shapefiles, CSVs, SDs, or TPKXs.
That action expects a local file path, so when you feed it a WMS URL instead, it ends up trying to open a path that doesn’t exist — hence the error:
TypeError: expected str, bytes or os.PathLike object, not NoneType
Your WMS is URL-based, not a file, so “Upload” isn’t the right action here.
donalmateer
Forum|alt.badge.img+10
  • November 21, 2025
