Spatial Join to add polygon data to points
tigercole
I have a shapefile that contains about 10'000 points and need to merge some data from a polygon shapefile that describes administrative areas. I need to add the relevant admin area data to each point.
Is there a way to do this in FME?
Best answer by nielsgerrits
Multiple ways to do this:
  • SpatialRelator
  • SpatialFilter
  • PointOnAreaOverlayer
  • Clipper
You need to check the Merge Attributes checkbox.
nielsgerrits
Forum|alt.badge.img+55
  • March 30, 2022
  • SpatialRelator
  • SpatialFilter
  • Clipper
@tigercole​ A bit more on the transformers suggested by @nielsgerrits​ can be found in this webinar or this series of articles
