Replace curve rings geometry with verctices
  • August 31, 2021
  • 61 views
bgeorges
Forum|alt.badge.img+5
Is there a way to replace curve rings in polygon geometries with vertices along the curve without generalizing the whole geometry.
The input is a feature class in a file geodatabase.
Thank you for the info!
Best answer by david_r
Have you tried the ArcStroker?
  • August 31, 2021
