Convert between different color values
sigtill
Forum|alt.badge.img+24
Have I missed a transformer to convert to/from for instance RGB 20,255,40 to fme_color?
  • November 3, 2015
Hi
You can use this expression:
@Evaluate(@Value(Red)/255.0),@Evaluate(@Value(Green)/255.0),@Evaluate(@Value(Blue)/255.0
David
sigtill
  • November 3, 2015
Thx! I had a workaround - just seemed to remember there was a transformer to convert between different color schemas - however I guess not :).
  • November 3, 2015
I was also surprised that I was unable to find any. I'll let you post the idea in the suggestion box.
mark2atsafe
Forum|alt.badge.img+48
  • November 3, 2015
Maybe it was a custom transformer from the store or knowledgebase that you were thinking about? I see the HTMLColorCalculator - although it only does hex and not RGB. I'll file a suggestion to add that functionality.
mark2atsafe
  • November 3, 2015
Added as PR#65379
