Write invalid records to a CSV writer
Hi I would like to output only the rejected records on each transformer output to a CSV file, and also write total count of invalid records.
Any suggestion what's the best way to achieve this?
erik_jan
Forum|alt.badge.img+19
  • July 28, 2017
Most important: Change the "Rejected Feature Handling" parameter to continue and not terminate the translation:
Then attach the CSV writer feature types to all Rejected ports you want recorded.
steveatsafe
Forum|alt.badge.img+12
If you are looking to get the sum of all features rejected you can use the Total Count Attribute of the StatisticCalculator and pass that information to a separate CSV feature type.
