STAR-APIC Mercator MCF Reader - not reading dto
ciarab
Forum|alt.badge.img+9
I have a large number of dto's created within Mercator which I can not read through the MCF Reader. I get the following error message
Error - Invalid data in file 'dto_test_notworking_t.dto'
Closing input file 'dto_test_notworking_t.dto'
MCF_READER_PIPELINE::f_1(SortFactory): Done sorting 0 feature(s)
Error - No bounding box coming out of the pipeline
Failed to specify the feature index as constraints on the reader
I also have a dto file that will read through the MCF Reader. I have tried to compare the structure of both files but the file produced in mercator seems significantly different to the one that will read through the Mercator MCF Reader.
Does anyone have experience with this data type and can identify what is wrong with my data ? Sample attached.
Thanks
Ciara
fmelizard
Forum|alt.badge.img+21
  • January 18, 2019
Hi @ciarab The error seems to have something to do with the bounding box. Please file a case via https://www.safe.com/support/report-a-problem/ Thanks!
ciarab
  • January 30, 2019
Thanks @DanAtSafe I have opened a case through our reseller
