Hi, I am using FME to write a Shapefile to PostGIS and I am wondering if there is a way that you can specify that it writes polygons only? When it is writing into PostGIS it is coming in as an unknown geometry with a warning triange!
Specifying the geometry type when writing from ESRI Shapefile into PostGIS
If you want to edit the geometry using PostGIS, you also need to add a ID field. I use a field pkey, type serial, Index PrimaryKey.
