POSTGIS Feature Writer in FME Workbench 2016 : Where do I set the TRANSACTION_INTERVAL?
fmelizard
Forum|alt.badge.img+21
  • August 4, 2017
Hi @grumblyfrown, you can set the Features Per Transaction in the Navigator, under the parameters for the PostGIS Writer.
  • August 8, 2017
Hi and thanks! However, this is not available with the FeatureWriter transformer which is what I need to use (I think :-)!)
fmelizard
  • August 8, 2017
Hi @grumblyfrown,
If you're running FME 2017.0 or higher, you can set the Features per Transaction in the FeatureWriter from the parameters dialog.
fmelizard
  • August 8, 2017
fmelizard wrote:
Hi @grumblyfrown,
Sorry, I missed you in my response! @g1 please check out the FeatureWriter in FME 2017.0
