Hello,
I am trying to download a small extent of OSM data using the OSMDownloader but the output osm file is empty (except for the header). The transformer generates the following call (which also specifies my bbox extent): http://overpass.osm.rambler.ru/cgi/xapi_meta?*[bbox=50.83,4.49,50.85,4.51]
The download action seems to be successful however because the outcome of the transformer comes out of the Success port.
Thanks for your help!
Best regards,
Olivier
