Thanks @david_r, that helped. Didn't know about that parameter.
But now - when starting the workspace in batch - no features are written. When starting the workbench everything works fine. Is that problem linked to that parameter?! Or is there anything different wrong...?!
I looked closer to the log and the batch file. It turned out it was a typing error. -.-
