How to read a value from an ECW file?
nicholas
Forum|alt.badge.img+14
I want to use the PythonCaller to read a value from the header of an ECW file.
The value I am looking for is four characters long, starting at the position of 37.
I want to then print the value.
This is the code I have so far;
import fme
import fmeobjects
# Template Function interface:
# When using this function, make sure its name is set as the value of
# the 'Class or Function to Process Features' transformer parameter
def processFeature(feature):
 pass
# Template Class Interface:
# When using this class, make sure its name is set as the value of
class FeatureProcessor(object):
 def __init__(self):
  pass
 def input(self,feature):
  print ('start')
  n = feature.getAttribute('fme_dataset')
  print (n)
  f = open(n,'rb')
  f.seek(37,0)
  print(f.read(4))
  f.close()
  self.pyoutput(feature)
  print ('finish')
 def close(self):
  pass
But it does not return the value that I am expecting
nicholas
  • August 25, 2022
I am making some progress
Here is new code
import fme
import fmeobjects
  pass
  def __init__(self):
    pass
    print ('start')
    file_name = feature.getAttribute('fme_dataset')
    print (file_name)
    ecw_file = open(file_name,'rb')
    ecw_file.seek(57,0)
    datum_string = ecw_file.read(9).decode('ascii')
    print('datum')
    print(datum_string)
    ecw_file.seek(73,0)
    projection_string = ecw_file.read(9).decode('ascii')
    print('projection')
    print(projection_string)
    ecw_file.close()
    print ('finish')
  def close(self):
    pass
nicholas
  • August 26, 2022
Here is new code
import fme
import fmeobjects
  pass
  def __init__(self):
    pass
    print ('start')
    print (file_name)
    ecw_file.seek(57,0)
    print('datum')
    print(datum_string)
    ecw_file.seek(73,0)
    print('projection')
    ecw_file.close()
    print ('finish')
  def close(self):
    pass
Code improved with a "with" statement
import fme
import fmeobjects
  pass
  def __init__(self):
    pass
    print ('start')
    print ('file')
    print (file_name)
    with open(file_name,'rb') as ecw_file:
      print('datum')
      ecw_file.seek(57,0)
      print(datum_string)
      print('projection')
      ecw_file.seek(73,0)
    print ('finish')
  def close(self):
    pass
  • August 29, 2022
Your code only prints the character it read from the file, it does not send it back to the workspace. For this you can replace these two lines:
With this single line:
feature.setAttribute('projection_string', ecw_file.read(9).decode('ascii'))
You'll have to manually expose the attribute "projection_string" in the PythonCaller.
PS, next time can you please post Python code using the Code Snippet formatting tool, it's much, much easier to read that way.
