I'm trying to write a GML-File using a workbench and a xsd-schema-file, which I got from someone else, but I get an error.
Obviously, there's something wrong in the xsd-File, as this error occurs when the schema document is beeing parsed, but how do I find out, what exactly is wrong?
(And strange enough, it used to work, I used to be able to generate the GML ...???)
The workbench used to be FME2015, but now I use FME2016, but get the same error in 2015 and 2016.
Creating writer for format: GML (Geography Markup Language) Trying to find a DYNAMIC plugin for writer named `GML' Loaded module 'GML' from file 'C:\\Program Files\\FME\\plugins/GML.dll' FME API version of module 'GML' matches current internal version (3.8 20151127) FME Configuration: No destination coordinate system set FME API version of module 'GML' matches current internal version (3.8 20151127) Writer `GML_1' of type `GML' using group definition keyword `GML_1_DEF' FME API version of module 'GML' matches current internal version (3.8 20151127) <GML_1 Writer> - Using GML 'GENERIC_APPLICATION_SCHEMA' profile writer The uri-map document 'C:\\Program Files\\FME\\xml\\urimap\\gml_aixm.xml' is being used to map from URI to URI The uri-map document 'C:\\Program Files\\FME\\xml\\urimap\\gml_citygml.xml' is being used to map from URI to URI The uri-map document 'C:\\Program Files\\FME\\xml\\urimap\\gml_inspire.xml' is being used to map from URI to URI The uri-map document 'C:\\Program Files\\FME\\xml\\urimap\\gml_urimap.xml' is being used to map from URI to URI URI 'file:///I:/AVG/Geoinformation/Projekte/AVG/2015.20 Datenabgabe Aggregationsinfrastruktur/40 Bearbeitung/SZ_MOpublic03_ili2_v13.xsd' mapped to 'file:///I:/AVG/Geoinformation/Projekte/AVG/2015.20 Datenabgabe Aggregationsinfrastruktur/40 Bearbeitung/SZ_MOpublic03_ili2_v13.xsd' Parsing schema document 'file:///I:/AVG/Geoinformation/Projekte/AVG/2015.20 Datenabgabe Aggregationsinfrastruktur/40 Bearbeitung/SZ_MOpublic03_ili2_v13.xsd' ... A fatal error has occurred. Check the logfile above for details ... Last line repeated 2 times ...
Thanks in advance
Vera
