gbxml Format
franco69
How is the  status to read/write gbxml format in FME?
Best answer by david_r
Green Builing XML doesn't seem to be directly supported: http://www.safe.com/fme/format-search/#search=xml
On the other hand, there are a good number of functions in FME that should make it possible to support the most basic object types without too much effort, I guess.
Some starting points: You might also want to contact Safe support (https://safecommunity.force.com/knowledgeSubmitCase) to see if gbXML support has been planned.
David
  • May 4, 2015
David
fmelizard
Forum|alt.badge.img+19
  • April 2, 2018
Safe internal PR#28282
deanatsafe
  • September 4, 2018
Take a look at this custom reader posted to FMEHub: https://hub.safe.com/formats/green-building-xml-gbxml
