feature merger and join using wildcard
HI All,
I never really thought about this one until now, but is it possible to featuremerge on wildcard values?
For example,
I have a point file with an ID value.  The ID values are unique.  ie A, B, C, D
I have a many table of values with a ID value of A_1990, A2, A, B1,B2,BC,D1,D3,D9
Is it possible feature merge based on a wild card?
ie..  *A* join to A_1990,A2
        *B* joins to B1,B2,BC
       *D* joins to D1,D3,D9
  • August 19, 2014
Thx for the quick reply.
I didn't think so either...I was trying to avoid doing a bunch of string manipulations.
  • August 19, 2014
you can probably do this using the InlineQuerier.
David
Forum|alt.badge.img+39
  • August 20, 2014
You should be able to extract the letter in one transformer using regularexpressions and then featuremerge.
e.g. by using something like regsub -all {[^A-Z+]} [FME_GetAttribute Anattribute] {} in a TCLCaller
