Hi, I am new in FME - I need a help. I would like to convert an PDF file to JPEG.
converting PDF to JPEG
- August 23, 2018
- 18 replies
- 490 views
- Evangelist
- 2059 replies
- August 23, 2018
Hi @tereziastredna
Just a question: your PDF file has image or text?
You can use the Reader PDF Geospatial or transformer to extract information PDF.
Could you share us your example data?
Thanks,
Danilo
- Evangelist
- 2059 replies
- August 23, 2018
Hi @tereziastredna
Thanks,
Danilo
- 98 replies
- August 23, 2018
Hi @tereziastredna
If you just want to make a JPEG image that looks exactly like your PDF, then you can use the "Non Spatial > Read Rasterized Pages" mode.
This will generate a feature type called "pdf_rasterized_pages", which will produce one raster per page. You can then send these features to a JPEG writer.
One interesting option is the "Raster Size > Mode". You can either use "Scale", like I did above, or you can make the rasters a custom size in pixels. I recommend trying a few different values for "Pixels per Point:", converting to JPEG, and seeing how the result looks. The bigger your "Pixels per Point" value, the larger your image will be.
PS. If you instead want to read JPEG images out of a PDF, rather than rendering the entire page, you want the "Spatial > Read Images" mode. I can tell you more about that mode if that is indeed what you're looking for.
- Author
- 59 replies
- August 24, 2018
Hello,
thanks to both of you.
My PDF file is a little bit of everything. Text, and images... see attached. test-pdf-to-jpeg.pdf
I tried to make it as you recommended jakemolnar, but I get an error. I am not sure what to change now. (to remove extra band) also attached error-fme.png
Thanks
- Celebrity
- 1899 replies
- August 24, 2018
Hello,
Thanks
The problem is because the PDF reader is generating an ALPHA band (which is used to control transparency). To remove it you can use a RasterInterpretationCoercer. Set the 'Destination Interpretation Type to 'RGB24'. Leave everything else default. You should then be able to write the image to JPEG.
- Author
- 59 replies
- August 24, 2018
- Celebrity
- 1899 replies
- August 24, 2018
- Celebrity
- 1899 replies
- August 24, 2018
If you add a RasterExpressionEvaluator and set it up like below this will set all the no data to white instead of black. Do this before you use the RasterInterpretationCoercer.
- Author
- 59 replies
- August 28, 2018
- Celebrity
- 1899 replies
- August 28, 2018
- Author
- 59 replies
- August 29, 2018
- Celebrity
- 1899 replies
- August 29, 2018
Oh dear. This is because the color bands must be in a mixed up order. I think the writer should work properly even if the bands are in the wrong order but the RasterExpressionEvaluator assumes the order is R>G>B>A. You may need to reorder the expression in the Elevator to match what comes into FME from the pdf reader. Alternatively you can use a RasterBandOrderer before the RasterExpressionEvaluator to order the bands in the standard way (RGBA). Perhaps @jakemolnar can see the order is gettign muddled by the pdf reader?
- Author
- 59 replies
- August 29, 2018
- Celebrity
- 1899 replies
- August 29, 2018
- Author
- 59 replies
- August 29, 2018
I have another problem :-(. I have a PDF files which consist of few pages (2-3). When I run the translation as recommended from you, the results are 2-3 sepatated files. I need to have them as an JPEG but as 1 file. I have no page numbers to set an attribute pdf_page_number. And what the worst is, I have a houndreds of this files. Some of them have only 1 page but some a few pages. So I need something what will also recognize what has more than 1 page. Do you have any idea how to join in together?
- Celebrity
- 1899 replies
- August 29, 2018
It's a fairly complex problem but if you ask give it a go and then ask a separate question when you get stuck I think you'll get some good help.
- 15 replies
- December 3, 2018
Hi @tereziastredna
@tereziastredna
I have a similar problem. I am converting pdfs to tiffs and am getting both color changes and rotation changes. I was hoping this non-spatial option would solve things but nothing comes out of the reader.
I have also tried the suggestions in the previous answer with the RasterInterpretationCoercer but when I do that, the only change is that the image in the inspector changes to the same incorrect color (bluish) as the output. If I output to a jpeg, the color is wrong but the orientation is ok.
So I need to figure out both how to maintain the color and orientation of the original document.
- Safer
- 327 replies
- December 4, 2018
@tereziastredna
Hi @justinv, I think it might be a good idea to post your issue as a new question. This thread is quite long already, so your new comment might not get noticed as easily. It would also help to add your sample data, workspace and log file to give some more background, so the community can provide suggestions based on your specific problem. Thank you!
Related Topics
How to fetch data from StoreKit testing framworkicon
General Questionsmigrating users from an existing appicon
Dashboard & ToolsHelp wanted: StoreKit 2 beta testing
SDKsawait Purchases.getOfferings(); hangs/never resolvesicon
SDKsexpirationDateMillis and originalAppUserId returned by Revenue Cat is wrongicon
SDKs
Helpful Members This Week
- nielsgerrits
17 votes
- hkingsbury
14 votes
- ebygomm
12 votes
- danilo_fme
12 votes
- crutledge
10 votes
- philippeb
9 votes
- takashi
7 votes
- liamfez
7 votes
- erik_jan
6 votes
- arcvancouver
6 votes
Recently Solved Questions
Read Settings from Delimited Text File
3 RepliesGeneric source file name confusion? Or bad workflow?
2 RepliesTruncate SDE table with archiving enabled
4 RepliesDissolver - Attributes to Sum and Multi Polygons:1+2 = 5
4 RepliesHow to see which features have invalid source datasets when using a FeatureWrite?
Community Stats
- 31,525
- Posts
- 119,505
- Replies
- 39,151
- Members
Latest FME
Scanning file for viruses.
Sorry, we're still checking this file's contents to make sure it's safe to download. Please try again in a few minutes.
OKThis file cannot be downloaded
Sorry, our virus scanner detected that this file isn't safe to download.
OKCookie policy
We use 3 different kinds of cookies. You can choose which cookies you want to accept. We need basic cookies to make this site work, therefore these are the minimum you can select. Learn more about our cookies.
