Hide Custom Transformer Internal Logging
  • February 1, 2022
  • 68 views
runneals
Forum|alt.badge.img+29
I'm playing around with security settings and it seems that if you password protect a custom transformer, it still spews out info in the logs from the internal guts of what's going on. Is there a way to prevent the internal guts of a custom transformer from being logged? Ie. I just want to show the input and output of the transformer. Is that possible? Seemed maybe like it was from this article https://community.safe.com/s/article/password-protection-for-fme-workspaces
Best answer by runneals
This is something we've discussed internally, keen to hear if there are any solutions
Go vote for the idea: https://community.safe.com/s/bridea/a0r4Q00000HcDMAQA3/hiding-custom-transformers-logging
hkingsbury
Forum|alt.badge.img+65
  • February 1, 2022
mark2atsafe
Forum|alt.badge.img+59
  • February 4, 2022
If a password is set then log_debug won't operate the same way. So there is some protection. A user shouldn't be able to recreate the contents fully from the log. But other than that, I don't think it had been considered before.
If you rename the transformers inside the custom transformer then the name gets logged, not necessarily the type. Like this:
But if you'd like to have it turned off completely, I think the best thing to do is to add this as an idea so other users can vote on it and we can gauge the demand.
runneals
  • February 4, 2022
hkingsbury
  • February 7, 2022
